Giriş
In this short guide, guidance will be provided on replacing the fan in the Lenovo 310-15IKB Laptop., in case it is damaged for is simply non-functional.
Neye ihtiyacın var
Flip the laptop over so the back panel is facing up.
Remove the single 6 mm screw from the L-shaped panel using a Phillips #0 screwdriver.
Neredeyse bitti!
To reassemble your device, follow these instructions in reverse order. Be careful to align the fan screw holes in place.
Sonuç
