Ana içeriğe geç
Lenovo Ideapad 320-15ABR Back Panel Replacement
Neye ihtiyacın var
  1. Lenovo Ideapad 320-15ABR Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Lenovo Ideapad 320-15ABR Back Panel Replacement: adım 2, 3 resimden 1. Lenovo Ideapad 320-15ABR Back Panel Replacement: adım 2, 3 resimden 2. Lenovo Ideapad 320-15ABR Back Panel Replacement: adım 2, 3 resimden 3.
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Lenovo Ideapad 320-15ABR Back Panel Replacement: adım 3, 2 resimden 1. Lenovo Ideapad 320-15ABR Back Panel Replacement: adım 3, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Lenovo Ideapad 320-15ABR Back Panel Replacement: adım 4, 3 resimden 1. Lenovo Ideapad 320-15ABR Back Panel Replacement: adım 4, 3 resimden 2. Lenovo Ideapad 320-15ABR Back Panel Replacement: adım 4, 3 resimden 3.
    • Use an opening tool to pry out the back cover.
  5. Lenovo Ideapad 320-15ABR Back Panel Replacement: adım 5, 3 resimden 1. Lenovo Ideapad 320-15ABR Back Panel Replacement: adım 5, 3 resimden 2. Lenovo Ideapad 320-15ABR Back Panel Replacement: adım 5, 3 resimden 3.
    • Remove the back panel by pulling it up and away from the laptop.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Anurag Deb
1.048 İtibar
3 adet Kılavuz yazıldı
Bir Yorum
How Is solved Twisted screw and broken inside the frame
For laptop ip520
mohsen JUVE - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 28
Son 30 gün: 131
Her zaman: 13,299
