Ana içeriğe geç
Lenovo Ideapad 320-15ABR Fan Replacement
Neye ihtiyacın var
  1. Lenovo Ideapad 320-15ABR Fan Replacement, Back Panel: adım 1, 1 resimden 1.
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Lenovo Ideapad 320-15ABR Fan Replacement: adım 2, 3 resimden 1. Lenovo Ideapad 320-15ABR Fan Replacement: adım 2, 3 resimden 2. Lenovo Ideapad 320-15ABR Fan Replacement: adım 2, 3 resimden 3.
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Lenovo Ideapad 320-15ABR Fan Replacement: adım 3, 2 resimden 1. Lenovo Ideapad 320-15ABR Fan Replacement: adım 3, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Lenovo Ideapad 320-15ABR Fan Replacement: adım 4, 3 resimden 1. Lenovo Ideapad 320-15ABR Fan Replacement: adım 4, 3 resimden 2. Lenovo Ideapad 320-15ABR Fan Replacement: adım 4, 3 resimden 3.
    • Use an opening tool to pry out the back cover.
  5. Lenovo Ideapad 320-15ABR Fan Replacement: adım 5, 3 resimden 1. Lenovo Ideapad 320-15ABR Fan Replacement: adım 5, 3 resimden 2. Lenovo Ideapad 320-15ABR Fan Replacement: adım 5, 3 resimden 3.
    • Remove the back panel by pulling it up and away from the laptop.
  6. Lenovo Ideapad 320-15ABR Fan Replacement, Battery: adım 6, 1 resimden 1.
    • Remove the four 6mm screws using the Phillips #1 screwdriver.
  7. Lenovo Ideapad 320-15ABR Fan Replacement: adım 7, 2 resimden 1. Lenovo Ideapad 320-15ABR Fan Replacement: adım 7, 2 resimden 2.
    • Disconnect the battery connector by pulling toward the battery parallel to the motherboard.
  8. Lenovo Ideapad 320-15ABR Fan Replacement: adım 8, 1 resimden 1.
    • Remove the battery.
  9. Lenovo Ideapad 320-15ABR Fan Replacement, Fan: adım 9, 2 resimden 1. Lenovo Ideapad 320-15ABR Fan Replacement, Fan: adım 9, 2 resimden 2.
    • Disconnect black and grey wires by simply giving them a light tug.
  10. Lenovo Ideapad 320-15ABR Fan Replacement: adım 10, 1 resimden 1.
    • Remove the 6mm Phillips #1 screw connecting the fan to the laptop.
  11. Lenovo Ideapad 320-15ABR Fan Replacement: adım 11, 3 resimden 1. Lenovo Ideapad 320-15ABR Fan Replacement: adım 11, 3 resimden 2. Lenovo Ideapad 320-15ABR Fan Replacement: adım 11, 3 resimden 3.
    • Lift the fan slightly and straight upward and unwind the black and grey wires from the fan.
  12. Lenovo Ideapad 320-15ABR Fan Replacement: adım 12, 1 resimden 1.
    • Identify the red, black, yellow, and brown wire coming from the back of the fan connecting to the motherboard with a white connector piece.
  13. Lenovo Ideapad 320-15ABR Fan Replacement: adım 13, 2 resimden 1. Lenovo Ideapad 320-15ABR Fan Replacement: adım 13, 2 resimden 2.
    • Slowly pull and wiggle the white connector piece until it comes loose from the laptop.
  14. Lenovo Ideapad 320-15ABR Fan Replacement: adım 14, 1 resimden 1.
    • Replace the new fan.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 42
Her zaman: 5,170
