Ana içeriğe geç
Lenovo Ideapad 320-15ABR Screen Replacement
Neye ihtiyacın var
  1. Lenovo Ideapad 320-15ABR Screen Replacement, Screen: adım 1, 3 resimden 1. Lenovo Ideapad 320-15ABR Screen Replacement, Screen: adım 1, 3 resimden 2. Lenovo Ideapad 320-15ABR Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Begin by prying off the black cover surrounding the screen by wedging the the iFixit opening tool underneath it. Work your way down until you reach the hinge cover.
    • Insert iFixit opening tool in to the hinge cover as pictured and begin slowly prying it off.
    • This will require some force, but take care not to break the hinge cover.
    • Remove the black cover.
  2. Lenovo Ideapad 320-15ABR Screen Replacement: adım 2, 3 resimden 1. Lenovo Ideapad 320-15ABR Screen Replacement: adım 2, 3 resimden 2. Lenovo Ideapad 320-15ABR Screen Replacement: adım 2, 3 resimden 3.
    • Using the Phillips #1 screwdriver, remove the four 3mm screws securing the screen, and put them on the magnetic mat so you will not misplace them.
    • Gently lift the screen out and place it facing down on the keyboard.
  3. Lenovo Ideapad 320-15ABR Screen Replacement: adım 3, 3 resimden 1. Lenovo Ideapad 320-15ABR Screen Replacement: adım 3, 3 resimden 2. Lenovo Ideapad 320-15ABR Screen Replacement: adım 3, 3 resimden 3.
    • Carefully flip the hinge securing the connector up with the opening tool.
    • Slowly work the plug out of the connector.
    • Do not pull by the the cable, as the cable is fragile.
    • Insert the plug from the replacement screen in to the connector. Make sure the connection is secure before flipping the hinge back down.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
How to replace hinge for this model
Deepak Singh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 4,570
