Ana içeriğe geç
Lenovo Ideapad 320-15IAP Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo Ideapad 320-15IAP Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. Lenovo Ideapad 320-15IAP Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back panel.
  2. Lenovo Ideapad 320-15IAP Hard Drive Replacement: adım 2, 2 resimden 1. Lenovo Ideapad 320-15IAP Hard Drive Replacement: adım 2, 2 resimden 2.
    • Remove the CD reader with an opening tool. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
    • Lift the cover using the opening tool on different spots along the side of the laptop.
  3. Lenovo Ideapad 320-15IAP Hard Drive Replacement: adım 3, 1 resimden 1.
    • Remove the hard drive by inserting your finger under the highlighted area, then pushing up then pulling left to remove the drive.
    • Remove the adapter from the drive, then insert the new drive into the adapter.
    • To insert the new drive, gently place it into the enclosure for the hard drive and push carefully into the SATA slot.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 52
Her zaman: 1,312
