Ana içeriğe geç
Lenovo Ideapad Flex 15 Bottom Panel Replacement
Neye ihtiyacın var
  1. Lenovo Ideapad Flex 15 Bottom Panel Replacement, Bottom Panel: adım 1, 2 resimden 1. Lenovo Ideapad Flex 15 Bottom Panel Replacement, Bottom Panel: adım 1, 2 resimden 2.
    • Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
    • Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
  2. Lenovo Ideapad Flex 15 Bottom Panel Replacement: adım 2, 2 resimden 1. Lenovo Ideapad Flex 15 Bottom Panel Replacement: adım 2, 2 resimden 2.
    • Once both feet are removed, two (40 mm) screws will reveal themselves. Unscrew these.
  3. Lenovo Ideapad Flex 15 Bottom Panel Replacement: adım 3, 3 resimden 1. Lenovo Ideapad Flex 15 Bottom Panel Replacement: adım 3, 3 resimden 2. Lenovo Ideapad Flex 15 Bottom Panel Replacement: adım 3, 3 resimden 3.
    • Working your way around the outer edges of the Flex 15, remove the 8 (30 mm) outer screws.
  4. Lenovo Ideapad Flex 15 Bottom Panel Replacement: adım 4, 1 resimden 1.
    • Remove the one (40 mm) screw in the middle of the Flex 15.
  5. Lenovo Ideapad Flex 15 Bottom Panel Replacement: adım 5, 3 resimden 1. Lenovo Ideapad Flex 15 Bottom Panel Replacement: adım 5, 3 resimden 2. Lenovo Ideapad Flex 15 Bottom Panel Replacement: adım 5, 3 resimden 3.
    • Using a plastic opening tool, make your way around the edge of the laptop.
    • There is a visible line between the bottom shell of the laptop and the laptop body itself.
  6. Lenovo Ideapad Flex 15 Bottom Panel Replacement: adım 6, 2 resimden 1. Lenovo Ideapad Flex 15 Bottom Panel Replacement: adım 6, 2 resimden 2.
    • Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
    • Using excessive force may break the bottom plastic. There are plastic clips along the edge of the laptop.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Brent
804 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-6, Bhusal Spring 2016 UMass Dartmouth, Team 6-6, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S6G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 2,858
