Giriş
To install new RAM, or replace the current RAM, this guide will walk you through the process.
Neye ihtiyacın var
Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
Once open, locate the RAM stick below the fan on the bottom right corner of the Flex 15.
At the same time, using two hands, pull both clips away from the RAM module.
3 farklı kişi bu kılavuzu tamamladı.
