Ana içeriğe geç
Lenovo Ideapad Flex 4-1570 Display Replacement
Neye ihtiyacın var
  1. Lenovo Ideapad Flex 4-1570 Display Replacement, Back Panel: adım 1, 1 resimden 1.
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 Display Replacement: adım 2, 1 resimden 1.
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 Display Replacement: adım 3, 1 resimden 1.
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 Display Replacement, Display: adım 4, 2 resimden 1. Lenovo Ideapad Flex 4-1570 Display Replacement, Display: adım 4, 2 resimden 2.
    • Use an opening tool to remove the three hinge bezels.
  5. Lenovo Ideapad Flex 4-1570 Display Replacement: adım 5, 1 resimden 1.
    • Remove the four 4 mm screws (two on each hinge) using a T5 Torx screwdriver.
  6. Lenovo Ideapad Flex 4-1570 Display Replacement: adım 6, 3 resimden 1. Lenovo Ideapad Flex 4-1570 Display Replacement: adım 6, 3 resimden 2. Lenovo Ideapad Flex 4-1570 Display Replacement: adım 6, 3 resimden 3.
    • Attach a suction handle to the corner of the display, then wedge the blade of a Jimmy between the display and its housing.
    • While sliding the Jimmy around the perimeter, place opening picks in the gap you created at regular intervals.
    • Once you've worked around the perimeter, lightly pull on the suction handle while gently prying with an opening tool until the display releases.
  7. Lenovo Ideapad Flex 4-1570 Display Replacement: adım 7, 1 resimden 1.
    • Use a T5 Torx screwdriver to remove the six 4 mm screws (three on each hinge) securing the hinges.
  8. Lenovo Ideapad Flex 4-1570 Display Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to remove the rubber stoppers in both hinges.
  9. Lenovo Ideapad Flex 4-1570 Display Replacement: adım 9, 1 resimden 1.
    • Remove the black foam over the black and white cords, to the left of the Wi-Fi card, using tweezers.
  10. Lenovo Ideapad Flex 4-1570 Display Replacement: adım 10, 1 resimden 1.
    • Disconnect the black cable near the fan using tweezers.
  11. Lenovo Ideapad Flex 4-1570 Display Replacement: adım 11, 1 resimden 1.
    • Remove the display from the rest of the computer.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 287
