Ana içeriğe geç
Lenovo Ideapad Flex 4-1570 Speakers Replacement
Neye ihtiyacın var
  1. Lenovo Ideapad Flex 4-1570 Speakers Replacement, Back Panel: adım 1, 1 resimden 1.
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 Speakers Replacement: adım 2, 1 resimden 1.
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 Speakers Replacement: adım 3, 1 resimden 1.
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 Speakers Replacement, Speakers: adım 4, 2 resimden 1. Lenovo Ideapad Flex 4-1570 Speakers Replacement, Speakers: adım 4, 2 resimden 2.
    • Lift up on each speaker, one by one. The speaker should lift up with ease.
  5. Lenovo Ideapad Flex 4-1570 Speakers Replacement: adım 5, 2 resimden 1. Lenovo Ideapad Flex 4-1570 Speakers Replacement: adım 5, 2 resimden 2.
    • Unwind the speaker wire from the plastic brackets. Once you have the wire completely unwinded, use two blue iFixit tools to disconnect the speaker chip from the motherboard.
Sonuç
Isaiah Vang
669 İtibar
6 adet Kılavuz yazıldı
Ekip
UW Stout, Team S6-G6, Ogden Fall 2018 UW Stout, Team S6-G6, Ogden Fall 2018 üyesi
UWSTOUT-OGDEN-F18S6G6
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 8
Her zaman: 210
