Ana içeriğe geç
Lenovo Ideapad S415 Touch Fan Replacement
Neye ihtiyacın var
  1. Lenovo Ideapad S415 Touch Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch Fan Replacement: adım 2, 1 resimden 1.
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch Fan Replacement: adım 3, 1 resimden 1.
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch Fan Replacement: adım 4, 1 resimden 1.
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch Fan Replacement: adım 5, 1 resimden 1.
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
  6. Lenovo Ideapad S415 Touch Fan Replacement, Fan: adım 6, 2 resimden 1. Lenovo Ideapad S415 Touch Fan Replacement, Fan: adım 6, 2 resimden 2.
    • Locate the five 6mm black screws on the bottom.
    • Using a Phillips #0 screwdriver, remove all five black screws.
  7. Lenovo Ideapad S415 Touch Fan Replacement: adım 7, 2 resimden 1. Lenovo Ideapad S415 Touch Fan Replacement: adım 7, 2 resimden 2.
    • Locate the three 4mm silver screws on the bottom area where the battery was removed.
    • Using the Phillips #0 screwdriver, remove all three silver screws.
  8. Lenovo Ideapad S415 Touch Fan Replacement: adım 8, 3 resimden 1. Lenovo Ideapad S415 Touch Fan Replacement: adım 8, 3 resimden 2. Lenovo Ideapad S415 Touch Fan Replacement: adım 8, 3 resimden 3.
    • Locate the four rubber stoppers near each corner of the laptop.
    • Open up the stoppers by lifting each with your fingers.
  9. Lenovo Ideapad S415 Touch Fan Replacement: adım 9, 3 resimden 1. Lenovo Ideapad S415 Touch Fan Replacement: adım 9, 3 resimden 2. Lenovo Ideapad S415 Touch Fan Replacement: adım 9, 3 resimden 3.
    • Under each of the four stoppers, there will be a 6mm screw.
    • Use the Phillips #0 screwdriver to remove all four screws.
  10. Lenovo Ideapad S415 Touch Fan Replacement: adım 10, 2 resimden 1. Lenovo Ideapad S415 Touch Fan Replacement: adım 10, 2 resimden 2.
    • Carefully open up the laptop to reveal the internal components.
  11. Lenovo Ideapad S415 Touch Fan Replacement: adım 11, 2 resimden 1. Lenovo Ideapad S415 Touch Fan Replacement: adım 11, 2 resimden 2.
    • Locate the silver 6mm screw on the top of the fan
    • Locate the silver 4mm screw on the bottom of the fan
    • Use a Phillips #0 screwdriver to remove both screws.
  12. Lenovo Ideapad S415 Touch Fan Replacement: adım 12, 2 resimden 1. Lenovo Ideapad S415 Touch Fan Replacement: adım 12, 2 resimden 2.
    • Locate the fan power connector.
    • Use a spudger or your hands to disconnect the fan power connector from its port.
  13. Lenovo Ideapad S415 Touch Fan Replacement: adım 13, 2 resimden 1. Lenovo Ideapad S415 Touch Fan Replacement: adım 13, 2 resimden 2.
    • Once the fan power connector is disconnected, lift up the bronze heatsink and pull the wires out from underneath it.
    • Lift up the fan and pull free.
Sonuç
Alexandria
363 İtibar
2 adet Kılavuz yazıldı
Ekip
UC Davis, Team S20-G5, Lore Winter 2019 UC Davis, Team S20-G5, Lore Winter 2019 üyesi
UCD-LORE-W19S20G5
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 190
