Ana içeriğe geç
Lenovo Ideapad S415 Touch Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo Ideapad S415 Touch Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch Hard Drive Replacement: adım 2, 1 resimden 1.
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch Hard Drive Replacement: adım 3, 1 resimden 1.
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch Hard Drive Replacement: adım 4, 1 resimden 1.
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch Hard Drive Replacement: adım 5, 1 resimden 1.
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
  6. Lenovo Ideapad S415 Touch Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 1. Lenovo Ideapad S415 Touch Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 2.
    • Locate the five black screws on the back.
    • Use a Phillips #0 screwdriver to remove all five black 6 mm screws.
  7. Lenovo Ideapad S415 Touch Hard Drive Replacement: adım 7, 2 resimden 1. Lenovo Ideapad S415 Touch Hard Drive Replacement: adım 7, 2 resimden 2.
    • Locate the three silver screws underneath the battery.
    • Use the Phillips #0 screwdriver to remove all three 4 mm screws.
  8. Lenovo Ideapad S415 Touch Hard Drive Replacement: adım 8, 3 resimden 1. Lenovo Ideapad S415 Touch Hard Drive Replacement: adım 8, 3 resimden 2. Lenovo Ideapad S415 Touch Hard Drive Replacement: adım 8, 3 resimden 3.
    • Locate the four rubber stoppers near each corner of the laptop.
    • Open up the stopper with your hands.
    • Use the Phillips #0 screwdriver to remove the 6 mm screws underneath all four stoppers.
  9. Lenovo Ideapad S415 Touch Hard Drive Replacement: adım 9, 1 resimden 1.
    • Open the laptop carefully.
  10. Lenovo Ideapad S415 Touch Hard Drive Replacement: adım 10, 2 resimden 1. Lenovo Ideapad S415 Touch Hard Drive Replacement: adım 10, 2 resimden 2.
    • Locate the hard drive.
    • Use the Phillips #0 screwdriver to remove the two 4 mm screws that are holding the hard drive in place.
  11. Lenovo Ideapad S415 Touch Hard Drive Replacement: adım 11, 1 resimden 1.
    • The hard drive is now removed from the laptop.
  12. Lenovo Ideapad S415 Touch Hard Drive Replacement: adım 12, 2 resimden 1. Lenovo Ideapad S415 Touch Hard Drive Replacement: adım 12, 2 resimden 2.
    • Once the hard drive is removed, locate the four screws that hold the metal frame to the hard drive.
    • Use the Phillips #0 screwdriver to remove the 4 mm silver screws on all sides.
Sonuç
Casey Zhang
315 İtibar
2 adet Kılavuz yazıldı
Ekip
UC Davis, Team S20-G5, Lore Winter 2019 UC Davis, Team S20-G5, Lore Winter 2019 üyesi
UCD-LORE-W19S20G5
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 473
