Ana içeriğe geç
Lenovo Ideapad S415 Touch RAM Replacement
Neye ihtiyacın var
  1. Lenovo Ideapad S415 Touch RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch RAM Replacement: adım 2, 1 resimden 1.
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch RAM Replacement: adım 3, 1 resimden 1.
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch RAM Replacement: adım 4, 1 resimden 1.
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch RAM Replacement: adım 5, 1 resimden 1.
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
  6. Lenovo Ideapad S415 Touch RAM Replacement, RAM: adım 6, 2 resimden 1. Lenovo Ideapad S415 Touch RAM Replacement, RAM: adım 6, 2 resimden 2.
    • Locate the five 6mm black screws on the bottom.
    • Using a Phillips #0 screwdriver, remove all five screws.
  7. Lenovo Ideapad S415 Touch RAM Replacement: adım 7, 2 resimden 1. Lenovo Ideapad S415 Touch RAM Replacement: adım 7, 2 resimden 2.
    • Locate the three 4mm silver screws on the bottom area where the battery was removed.
    • Use the Phillips #0 screwdriver to remove all three screws.
  8. Lenovo Ideapad S415 Touch RAM Replacement: adım 8, 3 resimden 1. Lenovo Ideapad S415 Touch RAM Replacement: adım 8, 3 resimden 2. Lenovo Ideapad S415 Touch RAM Replacement: adım 8, 3 resimden 3.
    • Locate the four rubber stoppers near each corner of the laptop.
    • Open up the stoppers by lifting each with your hands.
  9. Lenovo Ideapad S415 Touch RAM Replacement: adım 9, 3 resimden 1. Lenovo Ideapad S415 Touch RAM Replacement: adım 9, 3 resimden 2. Lenovo Ideapad S415 Touch RAM Replacement: adım 9, 3 resimden 3.
    • Under each of the four stoppers, there will be a 6mm screw.
    • Use the Phillips #0 screwdriver to remove all four screws.
  10. Lenovo Ideapad S415 Touch RAM Replacement: adım 10, 2 resimden 1. Lenovo Ideapad S415 Touch RAM Replacement: adım 10, 2 resimden 2.
    • Carefully open up the laptop to reveal the internal components.
  11. Lenovo Ideapad S415 Touch RAM Replacement: adım 11, 3 resimden 1. Lenovo Ideapad S415 Touch RAM Replacement: adım 11, 3 resimden 2. Lenovo Ideapad S415 Touch RAM Replacement: adım 11, 3 resimden 3.
    • Locate the RAM.
    • Using your hands gently push up on the two silver clips located on both ends of the RAM.
    • The RAM will spring out. Gently pull it out of the slot.
    • Do not touch the top yellow part of the RAM as this will cause damage.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alexandria
363 İtibar
2 adet Kılavuz yazıldı
Ekip
UC Davis, Team S20-G5, Lore Winter 2019 UC Davis, Team S20-G5, Lore Winter 2019 üyesi
UCD-LORE-W19S20G5
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 729
