Ana içeriğe geç
Lenovo Ideapad Yoga 2 11 Battery Replacement
Neye ihtiyacın var
  1. Lenovo Ideapad Yoga 2 11 Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Begin by turning your closed laptop so that you are looking at the bottom panel.
  2. Lenovo Ideapad Yoga 2 11 Battery Replacement: adım 2, 2 resimden 1. Lenovo Ideapad Yoga 2 11 Battery Replacement: adım 2, 2 resimden 2.
    • Locate the 10 screws (6mm) around the border of the panel.
    • Using the Torx T5 Screwdriver, remove the screws.
  3. Lenovo Ideapad Yoga 2 11 Battery Replacement: adım 3, 1 resimden 1.
    • Now that the screws are removed, gently lift the back panel upwards to detach it from the rest of your laptop.
  4. Lenovo Ideapad Yoga 2 11 Battery Replacement, Battery: adım 4, 2 resimden 1. Lenovo Ideapad Yoga 2 11 Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Locate the battery in the bottom right corner.
    • Using a Phillips #000, remove the 6 screws (3.5mm) on the border of the battery and the 7th screw (6.5mm) that is in the center of the battery.
  5. Lenovo Ideapad Yoga 2 11 Battery Replacement: adım 5, 3 resimden 1. Lenovo Ideapad Yoga 2 11 Battery Replacement: adım 5, 3 resimden 2. Lenovo Ideapad Yoga 2 11 Battery Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Locate the cable connecting to the battery. It is located at the top-center of the battery.
    • Use a pair of tweezers and place it so that the tweezer is around the cables. Gently pull the cables towards the battery to disconnect the cable.
  6. Lenovo Ideapad Yoga 2 11 Battery Replacement: adım 6, 2 resimden 1. Lenovo Ideapad Yoga 2 11 Battery Replacement: adım 6, 2 resimden 2.
    • There may be tape around the edge of the battery to secure some wires. Use a pair of tweezers to remove the tape so that the wires are no longer attached to the battery.
  7. Lenovo Ideapad Yoga 2 11 Battery Replacement: adım 7, 2 resimden 1. Lenovo Ideapad Yoga 2 11 Battery Replacement: adım 7, 2 resimden 2.
    • After you have unscrewed the screws, unplugged the cable, and removed the tape and wires, you can remove the battery from your laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Andria Chen
624 İtibar
5 adet Kılavuz yazıldı
Ekip
1Rehber Yorum
Excellent instructions makes it easy even for novice
bhimanagouda patil - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 33
Her zaman: 1,911
