Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. Lenovo Ideatab A1000 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling, Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 1, 3 resimden 1. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling, Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 1, 3 resimden 2. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling, Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 1, 3 resimden 3.
    • Unscrew the two Phillips screws under the memory card and the SIM card covers.
    • Use a plastic tool and remove the back cover.
  2. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 2, 3 resimden 1. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 2, 3 resimden 2. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 2, 3 resimden 3.
    • Unscrew the 8x screws and remove the mother board cover.
    • Disconnect the battery connector.
  3. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 3, 3 resimden 1. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 3, 3 resimden 2. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 3, 3 resimden 3.
    • Volume Buttons, Power Button and Vibration motor
    • Audio Jack Connector, Touch Screen Flex Cable connector, LCD Display Flex Cable Connector.
    • Wi-Fi Antenna Connector, Speaker Connector, GPS Antenna Connector.
  4. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 4, 3 resimden 1. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 4, 3 resimden 2. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 4, 3 resimden 3.
    • Remove the lower speaker and the microphone.
    • Unstuck the Power button, Volume buttons and Vibration motor from the middle frame.
    • Unhook the LCD Display and the Touch screen flex cables.
    • 2x Phillips screws securing the main board.
  5. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 5, 3 resimden 1. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 5, 3 resimden 2. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 5, 3 resimden 3.
    • Remove the Logic board.
    • Be careful, the mother board is sticked to the front outer case.
  6. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 6, 3 resimden 1. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 6, 3 resimden 2. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 6, 3 resimden 3.
    • CPU - Mediatek, MT8317ATA
    • Memory chip - eMMC(16GB)+LPDDR2(1GB) - KMK3U000VM-B410
    • Power management chip - Mediatek MT6329BA
    • That's all.
ZFix
195.826 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
329 Üyeler
1.453 adet Kılavuz yazıldı
2Kılavuz Yorumları
my mini usb track to board is damaged, can i repair it or can i know from where i can buy the PCB board for Lenovo Idea tab a1000
Jidendran S - Yanıt
Thanks for this guide!
Pooshon Banerjee - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 14,587
