Ana içeriğe geç
Lenovo Ideatab S6000 Battery Replacement
Görüntüleme: 14 B
İstatistikleri görüntüle:
Son 24 Saat:
2
Son 7 Gün:
14
Son 30 Gün:
105
Her zaman:
14.296
Yorumlar: 7
2 comments on steps, 5 guide comments.
Go to guide comments
Tamamlandı: 17
17 kişi bu kılavuzu "tamamlandı" olarak işaretledi. Sıradaki sen olacak mısın?
Sık Kullanılanlar: 0
Hiç kimse bu kılavuzu favorilere eklemedi (ve abone olmadı). İlk mi olacaksın?
Gerekli Süre: Tahmin yok
Zorluk: Orta
Guide the user in replacing the battery in order to fix power related problems of the Lenovo Ideatab S6000.
Neye ihtiyacın var
Aletler
    1. Lenovo Ideatab S6000 Battery Replacement, Battery: adım 1, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Remove the speaker screens by working them loose with a plastic opening tool. You may need to first loosen them with tweezers or a craft knife.
      • These screens are held in place by glue that is hard to remove. Please take your time to ensure that that this step is done correctly.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo Ideatab S6000 Battery Replacement: adım 2, 1 resimden 1.
      • Remove the screws from both of the spots that were covered.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo Ideatab S6000 Battery Replacement: adım 3, 1 resimden 1.
      • DO NOT USE A METAL TOOL FOR THIS.
      • Go all around the casing, prying the screen away from the backing with the spudger.
      • It will make a popping sound each time one of the lock tabs is disconnected.
      • Take your time as you move all around the device when prying the backing off.
      FixBot'a Sor
      Yorum Ekle
    4. Lenovo Ideatab S6000 Battery Replacement: adım 4, 1 resimden 1.
      • Pull off the plastic that is covering the battery cable.
      FixBot'a Sor
      Yorum Ekle
    5. Lenovo Ideatab S6000 Battery Replacement: adım 5, 2 resimden 1. Lenovo Ideatab S6000 Battery Replacement: adım 5, 2 resimden 2.
      • Using either the plastic opening tool or your fingers, gently pull on both sides of the plug to release it.
      FixBot'a Sor
      Yorum Ekle
    6. Lenovo Ideatab S6000 Battery Replacement: adım 6, 1 resimden 1.
      • Remove the battery by grabbing the tab shown and pulling up.
      • The battery is held to the device by adhesive. Pull the battery up from the tab and it will lift out with a bit of effort.
      FixBot'a Sor
      Yorum Ekle
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Josiah Speed
1.007 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-4, Brown Fall 2014 USF Tampa, Team 10-4, Brown Fall 2014 üyesi
USFT-BROWN-F14S10G4
4 Üyeler
60 adet Kılavuz yazıldı
5Kılavuz Yorumları
Does this guide apply to all variants of this model? The S6000L frame doesn't seem to pop away from the screen assembly the same way. Is there adhesive in any of the models?
Shelby Greenwall - Yanıt Paylaş
Can you recommend a professional who can help replace my Lenovo S600 battery.
Niyi Popoola - Yanıt Paylaş
The original Lenovo battery comes with the metal frame. In my case, the screw holes of the metal frame did not fit the screw holes of the base. Thus, I just pulled the new battery off its metal frame and just replaced the battery.
Joachim Keinert - Yanıt Paylaş
Great information. Thanks, you're a peach!
steve - Yanıt Paylaş
It was helpful.
acldebashis - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 105
Her zaman: 14,296
