Ana içeriğe geç
Lenovo Laptop T400 Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo Laptop T400 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • recommend to print out picture of the backside of the laptop and then use it as a template to place the screws on. They are many and different sizes.
    • Remove all bottom screws and place on template printout.
  2. Lenovo Laptop T400 Motherboard Replacement: adım 2, 2 resimden 1. Lenovo Laptop T400 Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove DVD drive. Toggle the "play triangle" switch so that the tab extends. Pull the tab to remove the DVD drive.
    • Remove hard drive
  3. Lenovo Laptop T400 Motherboard Replacement: adım 3, 3 resimden 1. Lenovo Laptop T400 Motherboard Replacement: adım 3, 3 resimden 2. Lenovo Laptop T400 Motherboard Replacement: adım 3, 3 resimden 3.
    • unsnap touchpad left and right.
    • lift up touchpad carefully, and disconnect touchpad.
  4. Lenovo Laptop T400 Motherboard Replacement: adım 4, 2 resimden 1. Lenovo Laptop T400 Motherboard Replacement: adım 4, 2 resimden 2.
    • Pull keyboard gently toward yourself. and then lift up untill flex is visible.
    • use spudger to disconnect connector for keyboard.
  5. Lenovo Laptop T400 Motherboard Replacement: adım 5, 1 resimden 1.
    • The rest of the guide is mosly helpfull pictures...
    • Remove WLAN module by
    • unplug carefully with spudger the two RF connectors to WLAN module.
    • remove the two screws holding wlan module.
    • lift up module 45 degress and pull outwards.
  6. Lenovo Laptop T400 Motherboard Replacement: adım 6, 3 resimden 1. Lenovo Laptop T400 Motherboard Replacement: adım 6, 3 resimden 2. Lenovo Laptop T400 Motherboard Replacement: adım 6, 3 resimden 3.
    • usefull images showing most of main assembly.
    • Removing RAM modules is usefull if the whole logic board needs to be taken out.
    • From here on , unscrew everything - carefully note where screws belong. I used Ifixit magnetic mat and some note making.
  7. Lenovo Laptop T400 Motherboard Replacement: adım 7, 1 resimden 1.
    • one more image to help you
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Carsten Dahl Hjarup
2.934 İtibar
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 53
Her zaman: 12,981
