Giriş
Use this guide to upgrade your current storage size for your Lenovo Legion 5-15ACH6 laptop.
The SSD Drive is a storage device that stores data in your computer. If you have a Lenovo Legion 5-15ACH6 laptop, you already have an SSD installed. However, if you are running low on storage space and wish to upgrade your SSD, you are in luck. The process to install additional storage is simple. Follow this easy step-by-step guide, and you should have plenty of storage in no time.
Be sure to backup your data on your current SSD so you don't lose it while you install your new SSD. Make sure to power off your laptop entirely before you start the process and unplug it from the charger.
Neye ihtiyacın var
Prepare your work area on a flat surface.
Lay your laptop down with the back case facing up.
3 farklı kişi bu kılavuzu tamamladı.
