Ana içeriğe geç
Lenovo Legion Y520-15IKBN Fan Replacement
Neye ihtiyacın var
  1. Lenovo Legion Y520-15IKBN Fan Replacement, Base Panel: adım 1, 2 resimden 1. Lenovo Legion Y520-15IKBN Fan Replacement, Base Panel: adım 1, 2 resimden 2.
    • Shut down and unplug your device before proceeding.
    • Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Fan Replacement: adım 2, 1 resimden 1.
    • Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
    • To get a better grip you may want to open the laptop slightly.
    • Lift the bottom panel off of the chassis.
    • During reassembly, make sure that the bottom panel clicks back into place on all four sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Fan Replacement, Fan: adım 3, 3 resimden 1. Lenovo Legion Y520-15IKBN Fan Replacement, Fan: adım 3, 3 resimden 2. Lenovo Legion Y520-15IKBN Fan Replacement, Fan: adım 3, 3 resimden 3.
    • There is a piece of plastic covering part of the RAM and the fan. You will need to remove this to get to the fan.
    • Unplug the battery then, you will need to remove the four 4 mm screws around the fan using a Phillips #00 screwdriver.
  4. Lenovo Legion Y520-15IKBN Fan Replacement: adım 4, 3 resimden 1. Lenovo Legion Y520-15IKBN Fan Replacement: adım 4, 3 resimden 2. Lenovo Legion Y520-15IKBN Fan Replacement: adım 4, 3 resimden 3.
    • Unscrew all the screws then unplug the wires connected to the fan.
    • Once all the wires are unplugged from the fan, move the wires aside to get the fan.
  5. Lenovo Legion Y520-15IKBN Fan Replacement: adım 5, 3 resimden 1. Lenovo Legion Y520-15IKBN Fan Replacement: adım 5, 3 resimden 2. Lenovo Legion Y520-15IKBN Fan Replacement: adım 5, 3 resimden 3.
    • Lift the fan out of the laptop body.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
Superb guide. thank you random citizen for creating this guide
Fikri Nur Nafi - Yanıt
Do I need to remove the fan if I want to clean it or add oil?
Ziro Hutt - Yanıt
Is there a way to open the fan to clean the dust from the blade ?
Apalagi08 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 54
Her zaman: 7,819
