Ana içeriğe geç
Lenovo Legion Y520-15IKBN Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo Legion Y520-15IKBN Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. Lenovo Legion Y520-15IKBN Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Remove the thirteen 6.5 mm screws from the bottom of the laptop using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Hard Drive Replacement: adım 2, 1 resimden 1.
    • Flip the laptop on its side and use a spudger or a credit card to pry the bottom covering off. To get a better grip you may want to open the laptop slightly.
    • The bottom piece will make popping noises as it is pulled from the laptop.
    • When reassembling make sure that the bottom piece clicks back into place on all sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Hard Drive Replacement: adım 3, 3 resimden 1. Lenovo Legion Y520-15IKBN Hard Drive Replacement: adım 3, 3 resimden 2. Lenovo Legion Y520-15IKBN Hard Drive Replacement: adım 3, 3 resimden 3.
    • The hard drive is a white square located on the right side of your device.
    • Use a Phillips #00 screwdriver to remove four 4.0 mm screws holding the hard drive in place.
  4. Lenovo Legion Y520-15IKBN Hard Drive Replacement: adım 4, 2 resimden 1. Lenovo Legion Y520-15IKBN Hard Drive Replacement: adım 4, 2 resimden 2.
    • Slide the hard drive from the device towards your right.
    • When reinstalling remember to slide the hard drive in from the right. Don't try to force it in from the front.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Hi,
does anyone know if replacing the 1TB hard disk with a 1TB SSD is possible? (I’m thinking in terms of cloning the whole disk: can I go for a 1TB SSD or do I need a bigger one? Do hidden partitions for restoring the system / this kind of stuff get copied correctly? Most tutorials online just copy the Windows partition: wouldn’t want to find out I can’t reset the system if needed.)
Cycy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 74
Her zaman: 12,550
