Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
Five 7 mm screws
Six 4 mm screws
Carefully pry the back cover off the computer using an opening pick.
Use a JIS #1 screwdriver to loosen the five spring screws located at the middle of the fan piece.
Remove the plastic covering after the screws have been loosened.
Use a JIS #1 screwdriver to remove four 4mm screws securing the fans to the device.
Unplug the wires connecting the two fans to the motherboard.
Lift the fans out of their positions and remove them from the device.
6 farklı kişi bu kılavuzu tamamladı.
4 Yorum
Thank you! Very clear and well photographed :)
Any recommended stores for the replacement fans?
Worked like a charm, thank you!!
where can i get a good replacement please
