Ana içeriğe geç
Lenovo Miix 2 Battery Replacement
Neye ihtiyacın var
  1. Lenovo Miix 2 Battery Replacement, Battery: adım 1, 2 resimden 1. Lenovo Miix 2 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
    • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
  2. Lenovo Miix 2 Battery Replacement: adım 2, 2 resimden 1. Lenovo Miix 2 Battery Replacement: adım 2, 2 resimden 2.
    • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
  3. Lenovo Miix 2 Battery Replacement: adım 3, 2 resimden 1. Lenovo Miix 2 Battery Replacement: adım 3, 2 resimden 2.
    • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
  4. Lenovo Miix 2 Battery Replacement: adım 4, 2 resimden 1. Lenovo Miix 2 Battery Replacement: adım 4, 2 resimden 2.
    • Remove the battery by prying up with your fingers or a plastic opening tool.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nicolas Jones
395 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-8, Maness Spring 2015 Cal Poly, Team 5-8, Maness Spring 2015 üyesi
CPSU-MANESS-S15S5G8
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 8,964
