Giriş
This procedure is necessary if the user runs into a problem where the buttons on the back cover are damaged or need to be readjusted due to significant use or damage from a drop or bump of the device. This guide will show how to remove the external buttons from the back cover.
Neye ihtiyacın var
Gently insert metal spudger into back panel of the device.
Remove the back cover with your hand.
Using the tweezers remove the volume button located towards the top of the device, near the rear camera cut out.
Next, gently lift up on the power button, once again using the tweezers, which is located above the volume button along the same side of the device.
Bir Yorum
pleas i need the Lenovo Miix 2 External Buttons on Back Cover how to find it it's has part nomber help me pls.
