Ana içeriğe geç
Lenovo N20p Chromebook Battery Replacement
Neye ihtiyacın var
  1. Lenovo N20p Chromebook Battery Replacement, Keyboard: adım 1, 2 resimden 1. Lenovo N20p Chromebook Battery Replacement, Keyboard: adım 1, 2 resimden 2.
    • Power down the Chromebook before starting any repair.
    • Remove the two 3.5 mm Phillips #0 screws using a screwdriver.
    • It is only necessary to remove these two screws to complete this step.
  2. Lenovo N20p Chromebook Battery Replacement: adım 2, 2 resimden 1. Lenovo N20p Chromebook Battery Replacement: adım 2, 2 resimden 2.
    • Use the hook of the metal spudger to carefully lift up the keyboard.
    • Lift the keyboard carefully. If you lift too quickly, it might break the two cables that connect the keyboard to the motherboard.
  3. Lenovo N20p Chromebook Battery Replacement: adım 3, 3 resimden 1. Lenovo N20p Chromebook Battery Replacement: adım 3, 3 resimden 2. Lenovo N20p Chromebook Battery Replacement: adım 3, 3 resimden 3.
    • Carefully, disconnect the keyboard cable from the motherboard carefully by pulling on the blue tab of the cable.
    • You will now be able to replace the keyboard.
  4. Lenovo N20p Chromebook Battery Replacement, Battery: adım 4, 3 resimden 1. Lenovo N20p Chromebook Battery Replacement, Battery: adım 4, 3 resimden 2. Lenovo N20p Chromebook Battery Replacement, Battery: adım 4, 3 resimden 3.
    • Remove the two rubber feet of the back of the Chromebook using a metal spudger.
    • Remove six bottom 3.5 mm Phillips #0 screws and two top 5 mm Phillips #1 screws.
  5. Lenovo N20p Chromebook Battery Replacement: adım 5, 1 resimden 1.
    • Remove all nine 3.5 mm Phillips #00 screws using a screwdriver.
  6. Lenovo N20p Chromebook Battery Replacement: adım 6, 2 resimden 1. Lenovo N20p Chromebook Battery Replacement: adım 6, 2 resimden 2.
    • Disconnect the battery cable from the motherboard.
    • Disconnect the touch-pad cable from the motherboard.
  7. Lenovo N20p Chromebook Battery Replacement: adım 7, 2 resimden 1. Lenovo N20p Chromebook Battery Replacement: adım 7, 2 resimden 2.
    • Use the metal spudger along the seam between the keyboard and the bottom of the Chromebook to lift up and remove the palm rest assembly.
    • It is normal for it to click loudly when it is released. Corner tags will be harder to release than other tags and will make a loud sound.
  8. Lenovo N20p Chromebook Battery Replacement: adım 8, 3 resimden 1. Lenovo N20p Chromebook Battery Replacement: adım 8, 3 resimden 2. Lenovo N20p Chromebook Battery Replacement: adım 8, 3 resimden 3.
    • Disconnect the USB cable from the motherboard by pulling the blue tab out of the cable.
    • Remove all five 3.0 mm Phillips #00 screws which connect the battery and motherboard.
  9. Lenovo N20p Chromebook Battery Replacement: adım 9, 2 resimden 1. Lenovo N20p Chromebook Battery Replacement: adım 9, 2 resimden 2.
    • Remove the battery.
    • It is helpful to lift and hold the battery as shown.
Sonuç
Shihao Cao
497 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G2, Cardinal Summer 2018 UW Tacoma, Team S1-G2, Cardinal Summer 2018 üyesi
UWT-CARDINAL-SU18S1G2
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 443
