Giriş
Once the keyboard and touch pad have been removed, the battery can be easily replaced by removing three screws and a connection cable.
Neye ihtiyacın var
Use a screwdriver to remove the six 5.0mm Phillips screws from the bottom housing of the Chromebook.
Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket.
My replacements did not come with the trackpad zif. I had to remove from the old part and move to the new part.
Remove the keyboard and trackpad panel away from the device.
Has anyone gone through the experience of replacing JUST the keyboard? It looks like they are available as a separate component, e.g. https://www.ebay.com/itm/New-for-Lenovo-... but I haven’t found a tutorial on removing the keyboard from its bezel. Thanks!
Disconnect the white charging cable connectors by pulling straight down on the connector.
7 farklı kişi bu kılavuzu tamamladı.
Where is write Protect Screw ???
Please
Lenovo N21 Chrome Book
MAC IT - Yanıt
