Ana içeriğe geç
Lenovo N22 Chromebook Battery Replacement
Neye ihtiyacın var
  1. Lenovo N22 Chromebook Battery Replacement, Keyboard: adım 1, 3 resimden 1. Lenovo N22 Chromebook Battery Replacement, Keyboard: adım 1, 3 resimden 2. Lenovo N22 Chromebook Battery Replacement, Keyboard: adım 1, 3 resimden 3.
    • Power down the Chromebook before starting the repair.
    • Opening the Chromebook voids the manufacturer warranty.
    • Flip the Chromebook so that the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
    • Use a spudger to remove each of the 4 rubber feet.
    • Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
  2. Lenovo N22 Chromebook Battery Replacement: adım 2, 3 resimden 1. Lenovo N22 Chromebook Battery Replacement: adım 2, 3 resimden 2. Lenovo N22 Chromebook Battery Replacement: adım 2, 3 resimden 3.
    • Flip the Chromebook back over and open the screen.
    • Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
    • Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
    • It is normal for the tabs to make a loud click when released. The corner tabs will be harder to release than the others and will make a louder click.
  3. Lenovo N22 Chromebook Battery Replacement: adım 3, 2 resimden 1. Lenovo N22 Chromebook Battery Replacement: adım 3, 2 resimden 2.
    • Once the keyboard is released, grab the two top corners closest to the screen and slowly lift the keyboard up.
    • Do not lift the keyboard quickly or you might break the two cables that connect the keyboard to the motherboard.
    • Disconnect the cables by lifting up the retaining flaps on the black ZIF connectors.
    • Slowly pull the cables up and out of the connectors.
  4. Lenovo N22 Chromebook Battery Replacement: adım 4, 1 resimden 1.
    • Lift the keyboard up and off the back panel, exposing the motherboard and battery.
  5. Lenovo N22 Chromebook Battery Replacement, Battery: adım 5, 2 resimden 1. Lenovo N22 Chromebook Battery Replacement, Battery: adım 5, 2 resimden 2.
    • Separate the battery cable from the motherboard by wedging the edge of a plastic opening tool between the black cable connector and the silver socket on the motherboard.
    • Pull the battery cable straight towards you, away from the silver socket.
  6. Lenovo N22 Chromebook Battery Replacement: adım 6, 2 resimden 1. Lenovo N22 Chromebook Battery Replacement: adım 6, 2 resimden 2.
    • Use a Philips #1 screwdriver to remove the three 4.3 mm screws securing the battery.
  7. Lenovo N22 Chromebook Battery Replacement: adım 7, 2 resimden 1. Lenovo N22 Chromebook Battery Replacement: adım 7, 2 resimden 2.
    • Lift up on the tabs that were held down by the screws to remove the battery.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Kevin Yerina
453 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S21-G1, Livingston Spring 2017 Cal Poly, Team S21-G1, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S21G1
4 Üyeler
14 adet Kılavuz yazıldı
4 Yorum
amazing!! thank you
Mark safoo - Yanıt
thanks I needed to take the bottom off so I can take a certain screw
xian panadero - Yanıt
cuck trentxluka
Jonathan Fritz - Yanıt
That's way too much just to take the battery out. it was helpful having these steps. Thank you
Becky Breneman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 49
Her zaman: 16,651
