Giriş
Through this guide you will be able to remove and replace individual keys on your keyboard. This process may be necessary if the key is not responsive to the touch.
Neye ihtiyacın var
Loosen the key by prying on the edge of the key with the plastic opening tool.
13 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Where can I order individual keys?
He tried to turn it on but it did not work
I took it off and now it broken he he
Yeah so I tried this on my computer to clean my keys and now my alt key won’t go back in. I also got my g key partially stuck in so only the right side of it works. Is there anything I am supposed to do?
My kid spilled sweet tea on his keyboard and the G and F were sticking. I was able to take off the keys by pushing the key from the left and then right edges enough for the plastic tab to clear the hole and come through. I applied more force than I was comfortable with for the key to come off but the two plastic pieces came off with it and separated. I had to reassemble them, correctly, and then put the key in at the lowest position and then push slide up to lock the plastic pieces in place along with the key. I honestly feel like I was going to break it when it came out the first time.
