Ana içeriğe geç
Lenovo N22 Chromebook Individual Key Replacement
Neye ihtiyacın var
  1. Lenovo N22 Chromebook Individual Key Replacement, Individual Key: adım 1, 1 resimden 1.
    • Power down the chromebook before starting this process.
    • Loosen the key by prying on the edge of the key with the plastic opening tool.
  2. Lenovo N22 Chromebook Individual Key Replacement: adım 2, 2 resimden 1. Lenovo N22 Chromebook Individual Key Replacement: adım 2, 2 resimden 2.
    • Remove the key from the keyboard by prying the key off with the opener or with your finger.
    • The key is connected to the keyboard with two connecting plastic squares. One is connected to the keyboard by tabs and one is connected to the keyboard by snaps.
    • When reassembling make sure that the two plastic square connectors are in the same place as when you removed the key.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Jackson Tucker
869 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S21-G1, Livingston Spring 2017 Cal Poly, Team S21-G1, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S21G1
4 Üyeler
14 adet Kılavuz yazıldı
6 Yorum
very vague info. If a Key does not work and I take it out, why should it work once back in?? what do I need to change or look for? seems like very good instructions to take the keys out of a notebook
edperalt - Yanıt
Where can I order individual keys?
Mallory Montreuil - Yanıt
He tried to turn it on but it did not work
Clayton Sensing - Yanıt
I took it off and now it broken he he
BRENNEN FIRKUS - Yanıt
Yeah so I tried this on my computer to clean my keys and now my alt key won’t go back in. I also got my g key partially stuck in so only the right side of it works. Is there anything I am supposed to do?
Anushka Halepet - Yanıt
My kid spilled sweet tea on his keyboard and the G and F were sticking. I was able to take off the keys by pushing the key from the left and then right edges enough for the plastic tab to clear the hole and come through. I applied more force than I was comfortable with for the key to come off but the two plastic pieces came off with it and separated. I had to reassemble them, correctly, and then put the key in at the lowest position and then push slide up to lock the plastic pieces in place along with the key. I honestly feel like I was going to break it when it came out the first time.
Charlie Dillard - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 29
Son 30 gün: 65
Her zaman: 14,350
