Ana içeriğe geç
Lenovo N23 Keyboard Replacement
Neye ihtiyacın var
  1. Lenovo N23 Keyboard Replacement, Removing Back Cover: adım 1, 1 resimden 1.
    • Power Down the Chromebook before starting the repair
    • Opening the Chromebook voids the manufacturer warranty
    • Flip the Chromebook so that the bottom is facing upwards
    • Use a Phillips #1 screwdriver to remove the eight 6.6 mm screws in the bottom.
  2. Lenovo N23 Keyboard Replacement, Opening up Keyboard: adım 2, 1 resimden 1.
    • Flip the Chromebook over and open the screen
    • Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook
    • Be careful of the tabs on the inside of the keyboard and Chromebook, be cautious or these could break, too
    • Run the plastic tool along the seam, popping up the keyboard until you can freely lift up the keyboard
    • It is normal for the tabs to make a loud popping sounds when released. The corner tabs are harder to remove and will make a louder click when released.
  3. Lenovo N23 Keyboard Replacement, Releasing Keyboard from Motherboard: adım 3, 1 resimden 1.
    • Once the keyboard is released, grab the top two corners closest to the screen and slowly lift the keyboard up
    • Do not lift the keyboard too quickly, or you might break the two cables that connect the keyboard to the motherboard
    • The motherboard is now exposed DO NOT use any tools with metal, you may short circuit and fry the motherboard
    • Disconnect the cables by lifting up on the retaining tabs on the blank ZIF connectors
    • Slowly pull the cables up and out of the connectors
  4. Lenovo N23 Keyboard Replacement: adım 4, 1 resimden 1.
    • Lift the keyboard up and off of the back retainers, completely removing the keyboard from the Chromebook
    • To reassemble your device, follow these instructions in reverse order.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Robin Mores
166 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 1,259
