Giriş
The Lenovo S20-30 netbook's battery life is decent, but will not last forever. It is common for the battery to need to be replaced after so many years. If your screen is unresponsive it may be due to a faulty battery. It is simple to replace the battery, so when your's does go out you can easily replace it. Battery parts range from $30-$100 depending on the kind you need. Here are the steps to replacing the battery in the Lenovo S20-30 netbook. No tools are required for this replacement.
Neye ihtiyacın var
Bir başkası bu kılavuzu tamamladı.
