Ana içeriğe geç
Lenovo S20-30 Display Monitor Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Lenovo S20-30 Display Monitor Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the Lenovo S20-30 over so that the bottom panel is facing upward.
  2. Lenovo S20-30 Display Monitor Replacement: adım 2, 1 resimden 1.
    • Slide the manual battery latch to the unlock position, so that the red is showing.
  3. Lenovo S20-30 Display Monitor Replacement: adım 3, 2 resimden 1. Lenovo S20-30 Display Monitor Replacement: adım 3, 2 resimden 2.
    • Slide and hold the spring-loaded battery latch on the other side (right) while sliding the battery out of the computer.
    • Grab new Lenovo S20-30 battery for replacement.
  4. Lenovo S20-30 Display Monitor Replacement, Display Monitor: adım 4, 2 resimden 1. Lenovo S20-30 Display Monitor Replacement, Display Monitor: adım 4, 2 resimden 2.
    • Pry open the frame using a plastic opening tool.
    • Pull frame upward to remove it.
  5. Lenovo S20-30 Display Monitor Replacement: adım 5, 2 resimden 1. Lenovo S20-30 Display Monitor Replacement: adım 5, 2 resimden 2.
    • Unscrew four M2 x 3mm screws using a Phillips #000 screwdriver.
  6. Lenovo S20-30 Display Monitor Replacement: adım 6, 2 resimden 1. Lenovo S20-30 Display Monitor Replacement: adım 6, 2 resimden 2.
    • Slowly remove display monitor to reveal the connector.
    • Remove the connector by gently pulling it out.
  7. Lenovo S20-30 Display Monitor Replacement: adım 7, 1 resimden 1.
    • Replace with new display monitor.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alexis Wesling
344 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 1,063
