Ana içeriğe geç
Lenovo Tab 2 A10-70 Power Button Replacement
Neye ihtiyacın var
  1. Lenovo Tab 2 A10-70 Power Button Replacement, Power Button: adım 1, 2 resimden 1. Lenovo Tab 2 A10-70 Power Button Replacement, Power Button: adım 1, 2 resimden 2.
    • Use a plastic opening tool to pry open the back cover of the tablet.
  2. Lenovo Tab 2 A10-70 Power Button Replacement: adım 2, 1 resimden 1.
    • The power button strip is only held in place by a small piece of double-sided tape.
    • Gently use the precision tweezers to separate the power button strip from the interior frame of the tablet.
  3. Lenovo Tab 2 A10-70 Power Button Replacement: adım 3, 1 resimden 1.
    • Be careful with the soldering iron to avoid injury.
    • Remove the power button from the motherboard.
    • Use the soldering iron to heat up the connections. Gently pull away from the motherboard after connections are detached.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tyler Hagenlocher
350 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-6, Eyestone Spring 2016 USF Tampa, Team 12-6, Eyestone Spring 2016 üyesi
USFT-EYESTONE-S16S12G6
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Thank you for making this helpfull instrutions.
Where i can get the Buttons?
Simon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 32
Her zaman: 6,785
