Ana içeriğe geç
Lenovo Tab 2 A7-20F Battery Replacement
Neye ihtiyacın var
  1. Lenovo Tab 2 A7-20F Battery Replacement, Case: adım 1, 2 resimden 1. Lenovo Tab 2 A7-20F Battery Replacement, Case: adım 1, 2 resimden 2.
    • Starting at any point along the seam of the case carefully pry it open with the metal spudger, slowly working your way around the outside until the case can come apart.
  2. Lenovo Tab 2 A7-20F Battery Replacement, Battery: adım 2, 2 resimden 1. Lenovo Tab 2 A7-20F Battery Replacement, Battery: adım 2, 2 resimden 2.
    • The battery is connected to the motherboard by the thin wire shown here.
    • Pull up gently on the yellow tape to access the connector.
  3. Lenovo Tab 2 A7-20F Battery Replacement: adım 3, 1 resimden 1.
    • Gently detach the connector from the motherboard by pulling up on it.
  4. Lenovo Tab 2 A7-20F Battery Replacement: adım 4, 3 resimden 1. Lenovo Tab 2 A7-20F Battery Replacement: adım 4, 3 resimden 2. Lenovo Tab 2 A7-20F Battery Replacement: adım 4, 3 resimden 3.
    • There is double-sided tape inside the case.
    • Use the spudger tool to loosen the bond of the adhesive from the double sided tape.
    • Separate the battery from the case.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Thanh
357 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 3,172
