Ana içeriğe geç
Lenovo ThinkCentre M92p Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo ThinkCentre M92p Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 1. Lenovo ThinkCentre M92p Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 2. Lenovo ThinkCentre M92p Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 3.
    • Power off your ThinkCentre M92p, and unplug the power cable from the electrical outlet.
  2. Lenovo ThinkCentre M92p Hard Drive Replacement: adım 2, 2 resimden 1. Lenovo ThinkCentre M92p Hard Drive Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the middle black screw located on the back of the ThinkCentre.
  3. Lenovo ThinkCentre M92p Hard Drive Replacement: adım 3, 3 resimden 1. Lenovo ThinkCentre M92p Hard Drive Replacement: adım 3, 3 resimden 2. Lenovo ThinkCentre M92p Hard Drive Replacement: adım 3, 3 resimden 3.
    • Use your thumbs and slide the metal housing towards the front, to remove the cover.
  4. Lenovo ThinkCentre M92p Hard Drive Replacement: adım 4, 2 resimden 1. Lenovo ThinkCentre M92p Hard Drive Replacement: adım 4, 2 resimden 2.
    • Unplug the black connector from the damaged hard drive.
  5. Lenovo ThinkCentre M92p Hard Drive Replacement: adım 5, 3 resimden 1. Lenovo ThinkCentre M92p Hard Drive Replacement: adım 5, 3 resimden 2. Lenovo ThinkCentre M92p Hard Drive Replacement: adım 5, 3 resimden 3.
    • Use the Phillips #1 screwdriver to remove the two black screws holding the hard drive to the chassis.
  6. Lenovo ThinkCentre M92p Hard Drive Replacement: adım 6, 3 resimden 1. Lenovo ThinkCentre M92p Hard Drive Replacement: adım 6, 3 resimden 2. Lenovo ThinkCentre M92p Hard Drive Replacement: adım 6, 3 resimden 3.
    • Do not try to remove the hard drive right away .There is a red/black cable connected to the motherboard, right below the hard drive. Gently disconnect it from the *green* motherboard***.
  7. Lenovo ThinkCentre M92p Hard Drive Replacement: adım 7, 3 resimden 1. Lenovo ThinkCentre M92p Hard Drive Replacement: adım 7, 3 resimden 2. Lenovo ThinkCentre M92p Hard Drive Replacement: adım 7, 3 resimden 3.
    • Flip over the disconnected caddy/tray and use the Phillips #1 screwdriver to remove the four screws from the bottom. Then remove the hard drive.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Innocent bakajika
217 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 31
Son 30 gün: 132
Her zaman: 5,260
