Ana içeriğe geç
Lenovo ThinkPad Edge E520 Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Power off and unplug the computer before the start of these steps.
    • Close the laptop lid.
  2. Lenovo ThinkPad Edge E520 Hard Drive Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad Edge E520 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Flip the computer so that the back is facing upwards.
    • Locate the switch used to release the battery.
    • The switch should be located towards the hinge of the laptop near the battery pack and have a lock icon associated with it.
  3. Lenovo ThinkPad Edge E520 Hard Drive Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad Edge E520 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Slide the switch towards the unlocked lock icon.
    • While holding it in the unlocked position, slide the battery towards the hinge.
    • Fully separate the battery pack from the back of the laptop.
  4. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Back Plate: adım 4, 2 resimden 1. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Back Plate: adım 4, 2 resimden 2.
    • Flip over the laptop and position it with the battery being furthest away from you.
    • Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
    • Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
    • Screw length 6.35 mm, head 3.175 mm
  5. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Hard Drive: adım 5, 3 resimden 1. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Hard Drive: adım 5, 3 resimden 2. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Hard Drive: adım 5, 3 resimden 3.
    • Position the laptop so that the battery compartment is facing away from you.
    • Remove the two bracket screws on the bottom of the hard drive.
    • Gently lift out the hard drive with its bracket still attached.
    • Remove the bracket from the hard drive.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
David Skarbek
271 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G2, Simcock Spring 2018 UMass Dartmouth, Team S1-G2, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S1G2
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 20
Her zaman: 1,425
