Giriş
This guide assists you in replacing the USB Drive for the Lenovo Thinkpad Edge E520.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Flip over the laptop and position it with the battery being furthest away from you.
Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
Screw length 6.35 mm, head 3.175 mm
There are two screws that have keyboard symbols pointing at them.
Unscrew the screws with a 3.175 mm diameter and 6.35 mm length with a Phillips head screwdriver.
Remove all remaining screws on the back of the device.
Screw length 6.35 mm, head 3.175 mm Screws behind battery length 3.175 mm, head 3.175 mm
There is a silver rectangle next to the CD drive.
Remove the black tray from the silver rectangular box.
