Ana içeriğe geç
Lenovo ThinkPad Edge E530 HDD Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Lenovo ThinkPad Edge E530 HDD Replacement, HDD Cover: adım 1, 3 resimden 1. Lenovo ThinkPad Edge E530 HDD Replacement, HDD Cover: adım 1, 3 resimden 2. Lenovo ThinkPad Edge E530 HDD Replacement, HDD Cover: adım 1, 3 resimden 3.
    • Switch-off the Laptop and remove the battery.
    • The HDD/Memory Cover is held by 3x Phillips screws. Remove them.
    • Remove the Cover.
  2. Lenovo ThinkPad Edge E530 HDD Replacement, HDD (Hard Disk Drive): adım 2, 3 resimden 1. Lenovo ThinkPad Edge E530 HDD Replacement, HDD (Hard Disk Drive): adım 2, 3 resimden 2. Lenovo ThinkPad Edge E530 HDD Replacement, HDD (Hard Disk Drive): adım 2, 3 resimden 3.
    • There are 2 x philips screws, securing the HDD Caddy Case. Remove them and slide the HDD to disconnect it from the SATA Connector.
    • The Caddy Case is held to the HDD by 4x Phillips screws. Remove them and separate the HDD from the case.
    • After installing the new HDD you must install a new OS or clone your old HDD.
    • You can install SATA HDD, 2.5" up to 1TB.
    • Did you do it successfully?
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
ZFix
191.055 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.506 adet Kılavuz yazıldı
2 Yorum
Since you mention cloning, it would be good to know how to clone one’s old drive. Would this also clone any errors on the oldrive and then put them on the new drive???
David Abineri - Yanıt
Thanks for the guide. It also works for the ThinkPad Edge E531 model.
Célestin Taramarcaz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 10,171
