Ana içeriğe geç
Lenovo ThinkPad Helix Battery Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad Helix Battery Replacement, Screen: adım 1, 1 resimden 1.
    • Using a plastic opening tool or opening pick, gently pry the screen off.
    • If possible, use plastic tools to pry the screen, as the metal tool as shown in the image can potentially damage your device.
    • You will need to use a little bit of force to pry it open. There is little indent that goes around the tablet. You will insert your tool between this indent and pry it open.
    • Once you're able to lift a little bit of the screen away from the tablet, work your way around until screen is separated from tablet. Stop for step two.
  2. Lenovo ThinkPad Helix Battery Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad Helix Battery Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad Helix Battery Replacement: adım 2, 3 resimden 3.
    • Lift the screen up slowly.
    • Once separated, you can not fully take it off due to some cable connections.
    • Open the clips of the ZIF connectors and gently grab the cable to pull it out.
  3. Lenovo ThinkPad Helix Battery Replacement: adım 3, 1 resimden 1.
    • Once the cables are disconnected, remove the screen.
  4. Lenovo ThinkPad Helix Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Using a Phillips #00 screwdriver, unscrew the four nylon-coated 3 mm screws holding the battery in place.
  5. Lenovo ThinkPad Helix Battery Replacement: adım 5, 2 resimden 1. Lenovo ThinkPad Helix Battery Replacement: adım 5, 2 resimden 2.
    • Disconnect the battery cable from the motherboard.
    • Lift the battery out of the device.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Manuel Parra Rocha
494 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team S1-G6, Saknee Fall 2019 Gateway, Team S1-G6, Saknee Fall 2019 üyesi
GCC-SAKNEE-F19S1G6
4 Üyeler
3 adet Kılavuz yazıldı
Bir Yorum
Hi, would you possibly have an explanation as to why a replacement battery is still not charging and yielding error messages? Thank you.
M.H. L. - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 21
Son 30 gün: 89
Her zaman: 6,840
