Ana içeriğe geç
Lenovo ThinkPad Helix Screen Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad Helix Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Using a plastic opening tool or opening pick, gently pry the screen off.
    • If possible, use plastic tools to pry the screen, as the metal tool as shown in the image can potentially damage your device.
    • You will need to use a little bit of force to pry it open. There is little indent that goes around the tablet. You will insert your tool between this indent and pry it open.
    • Once you're able to lift a little bit of the screen away from the tablet, work your way around until screen is separated from tablet. Stop for step two.
  2. Lenovo ThinkPad Helix Screen Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad Helix Screen Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad Helix Screen Replacement: adım 2, 3 resimden 3.
    • Lift the screen up slowly.
    • Once separated, you can not fully take it off due to some cable connections.
    • Open the clips of the ZIF connectors and gently grab the cable to pull it out.
  3. Lenovo ThinkPad Helix Screen Replacement: adım 3, 1 resimden 1.
    • Once the cables are disconnected, remove the screen.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Manuel Parra Rocha
494 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team S1-G6, Saknee Fall 2019 Gateway, Team S1-G6, Saknee Fall 2019 üyesi
GCC-SAKNEE-F19S1G6
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 1,875
