Ana içeriğe geç
Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Remove base cover: adım 1, 1 resimden 1.
    • Remove the 7 screws holding the base cover in place.
    • Remove the base cover.
  2. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Unplug the battery: adım 2, 1 resimden 1.
    • Peel up the insulated sheet from the battery connector.
    • Unplug the battery connector in the direction showed by the arrow.
  3. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Remove the battery screws: adım 3, 1 resimden 1.
    • Remove the two M2 × L4 mm, flat-head screws.
    • Remove the two M2 × L5 mm, flat-head, screws.
  4. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Remove the battery: adım 4, 1 resimden 1.
    • Remove the battery.
Sonuç
To replace the battery & reassemble your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Max Kletskov
40.307 İtibar
16 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.392 adet Kılavuz yazıldı
3 Yorum
Great Thank you for info
Brad - Yanıt
Will this battery generate a Bios not authentic battery warning? Other replacement batteries would not charge in my P1 Gen2 ThinkPad.
hello - Yanıt
Is it compatible for Lenovo Thinkpad P1 Gen1 Type 20MD ?
k2ki - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 55
Son 30 gün: 324
Her zaman: 11,154
