Ana içeriğe geç
Lenovo ThinkPad P50s Base Cover Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad P50s Base Cover Replacement, Battery: adım 1, 2 resimden 1. Lenovo ThinkPad P50s Base Cover Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the device over so the bottom is facing you.
  2. Lenovo ThinkPad P50s Base Cover Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad P50s Base Cover Replacement: adım 2, 2 resimden 2.
    • Use your thumb to slide the right lock switch button outward.
  3. Lenovo ThinkPad P50s Base Cover Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad P50s Base Cover Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad P50s Base Cover Replacement: adım 3, 3 resimden 3.
    • With your thumb slide the left lock switch button outward while sliding the battery out with your other hand.
    • When replacing the battery, make sure that the connectors are aligned properly.
    • You may hear a click when the battery is fully seated and the lock engages.
  4. Lenovo ThinkPad P50s Base Cover Replacement, Base Cover: adım 4, 2 resimden 1. Lenovo ThinkPad P50s Base Cover Replacement, Base Cover: adım 4, 2 resimden 2.
    • Use a Phillips #00 screwdriver to unscrew the eight 2 mm captive screws.
    • These screws should not be removed entirely; you will be able to take off the base cover once they are loosened.
  5. Lenovo ThinkPad P50s Base Cover Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad P50s Base Cover Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad P50s Base Cover Replacement: adım 5, 3 resimden 3.
    • With the plastic opening tool, pry up the base cover.
    • Slide the opening tool around the edge of the laptop to release the snap tabs.
    • You may need to use opening picks to hold the tabs apart, as the base is securely attached and tends to snap back into place.
  6. Lenovo ThinkPad P50s Base Cover Replacement: adım 6, 2 resimden 1. Lenovo ThinkPad P50s Base Cover Replacement: adım 6, 2 resimden 2.
    • Lift the base cover off the laptop.
Sonuç
Jaylan
645 İtibar
4 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 54
