Ana içeriğe geç
Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, Hard Disk Drive: adım 1, 2 resimden 1. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, Hard Disk Drive: adım 1, 2 resimden 2.
    • Remove the 8 screws that hold down the back panel using the Phillips #000 screwdriver.
  2. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: adım 2, 1 resimden 1.
    • Remove the two M2 x 3 mm, wafer-head, nylon-coated screws that hold down the hard drive assembly using the Phillips #0 screwdriver.
  3. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: adım 3, 1 resimden 1.
    • Pull the hard drive assembly out with backside up.
  4. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: adım 4, 1 resimden 1.
    • Remove the four M3 x 3 mm, flat-head, nylon-coated screws on the side of the hard drive assembly using the Phillips #0 screwdriver.
  5. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: adım 5, 1 resimden 1.
    • Gently, remove the plastic cover with the blue strips.
  6. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, HDMI-USB Jack assembly: adım 6, 2 resimden 1. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, HDMI-USB Jack assembly: adım 6, 2 resimden 2.
    • Remove the 3 screws holding down the T shaped cover using the Phillips head #1. Two of the screws are M2.5x 4 wafer head. The other is a M2x4MM.
    • The two similar screws have blue threading around them.
  7. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: adım 7, 2 resimden 2.
    • Use the opening tool to lift up the T shaped cover.
    • Remove the M2x3MM wafer head screw.
  8. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: adım 8, 3 resimden 3.
    • Take off the 2 M2x3MM wafered screws holding down the chip top of assembly.
    • Lift the chip to release the HDMI-USB jack assembly
  9. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: adım 9, 1 resimden 1.
    • Detach the connector.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 280
