Ana içeriğe geç
Lenovo ThinkPad S431 Hard Disk Drive Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad S431 Hard Disk Drive  Replacement, Hard Disk Drive: adım 1, 2 resimden 1. Lenovo ThinkPad S431 Hard Disk Drive  Replacement, Hard Disk Drive: adım 1, 2 resimden 2.
    • Remove the 8 screws that hold down the back panel using the Phillips #000 screwdriver.
  2. Lenovo ThinkPad S431 Hard Disk Drive  Replacement: adım 2, 1 resimden 1.
    • Remove the two M2 x 3 mm, wafer-head, nylon-coated screws that hold down the hard drive assembly using the Phillips #0 screwdriver.
  3. Lenovo ThinkPad S431 Hard Disk Drive  Replacement: adım 3, 1 resimden 1.
    • Pull the hard drive assembly out with backside up.
  4. Lenovo ThinkPad S431 Hard Disk Drive  Replacement: adım 4, 1 resimden 1.
    • Remove the four M3 x 3 mm, flat-head, nylon-coated screws on the side of the hard drive assembly using the Phillips #0 screwdriver.
  5. Lenovo ThinkPad S431 Hard Disk Drive  Replacement: adım 5, 1 resimden 1.
    • Gently, remove the plastic cover with the blue strips.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 747
