Ana içeriğe geç
Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 1. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 2.
    • For your safety, discharge your battery below 25% before disassembling your laptop. A charged battery may catch fire if damaged. If your battery is swollen, take appropriate precautions.
    • Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
    FixBot'a Sor
    Yorum Ekle
  2. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Loosen the base cover screws: adım 2, 2 resimden 1. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Loosen the base cover screws: adım 2, 2 resimden 2.
    • Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
    FixBot'a Sor
    Yorum Ekle
  3. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Remove the base cover: adım 3, 3 resimden 1. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Remove the base cover: adım 3, 3 resimden 2. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Remove the base cover: adım 3, 3 resimden 3.
    • The base cover is still lightly clipped to the laptop.
    • Use your fingers to grab and lift the top-right corner of the base cover near the hinge.
    • Repeat at the top-left corner.
    FixBot'a Sor
    Yorum Ekle
  4. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement: adım 4, 3 resimden 3.
    • Slowly lift the hinge edge of the base cover until the remaining clips release.
    • Remove the base cover.
    • During reassembly, align the base cover's bottom edge tabs with the laptop, then lay the cover in place. Press around the perimeter to clip the base cover to the laptop.
    FixBot'a Sor
    Yorum Ekle
  5. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Disconnect the battery: adım 5, 3 resimden 1. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Disconnect the battery: adım 5, 3 resimden 2. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Disconnect the battery: adım 5, 3 resimden 3.
    • Use your fingers to squeeze the two latches on either side of the battery connector.
    • While squeezing the latches, lift the top edge of the battery up.
    FixBot'a Sor
    Yorum Ekle
  6. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Remove the battery: adım 6, 2 resimden 1. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Remove the battery: adım 6, 2 resimden 2.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
  7. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Remove the LPCAMM2 cover: adım 7, 1 resimden 1.
    • Use a Phillips screwdriver to loosen the three captive screws securing the LPCAMM2 cover.
    • During reassembly, tighten the screws in the order printed on the cover.
    FixBot'a Sor
    Yorum Ekle
  8. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement: adım 8, 2 resimden 1. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement: adım 8, 2 resimden 2.
    • Lift and remove the LPCAMM2 cover.
    FixBot'a Sor
    Yorum Ekle
  9. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Remove the LPCAMM2 memory: adım 9, 2 resimden 1. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Remove the LPCAMM2 memory: adım 9, 2 resimden 2.
    • Grab the edges of the LPCAMM2 memory module and lift straight up to remove it.
    • Avoid touching the gold underside of the module—your skin oils can interfere with the electrical contacts. If you touch it by accident and plan to re-use it, clean it with high-concentration isopropyl alcohol (>90%) and a lint-free cloth before reinstalling it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
343.532 İtibar
915 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 58
Son 30 gün: 307
Her zaman: 3,668
