Ana içeriğe geç
Lenovo ThinkPad T400s Keyboard Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T400s Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. Lenovo ThinkPad T400s Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Remove the Phillips #0-6mm screw.
    • Lift up the back cover to the RAM cards.
  2. Lenovo ThinkPad T400s Keyboard Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad T400s Keyboard Replacement: adım 2, 2 resimden 2.
    • Pull the lock for the baterry to the left to unlock.
    • While holding the tab in the unlocked position, remove the battery.
  3. Lenovo ThinkPad T400s Keyboard Replacement: adım 3, 1 resimden 1.
    • Remove the three Phillips #0-6mm screws on the back panel.
    • These screws are marked with a keyboard symbol next to them.
  4. Lenovo ThinkPad T400s Keyboard Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad T400s Keyboard Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad T400s Keyboard Replacement: adım 4, 3 resimden 3.
    • Turn the computer over and open the lid.
    • Wedge the small metal spudger between the palm rest and the keyboard.
  5. Lenovo ThinkPad T400s Keyboard Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T400s Keyboard Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T400s Keyboard Replacement: adım 5, 3 resimden 3.
    • Lift up the keyboard, but be careful not to completely remove.
    • Don't lift the keyboard too quickly, there is a connector cable you must disconnect first.
    • Wedge the small plastic opening tool underneath copper band and tilt back.
    • Remove keyboard to replace.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Morgan Montalvo
652 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-18, Maness Spring 2015 Cal Poly, Team 6-18, Maness Spring 2015 üyesi
CPSU-MANESS-S15S6G18
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 32
Her zaman: 1,572
