Ana içeriğe geç
Lenovo ThinkPad T400s LCD Screen Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T400s LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Use a #0 Phillips head screwdriver to remove the two 3mm screws that hold the screen bezel in place.
  2. Lenovo ThinkPad T400s LCD Screen Replacement: adım 2, 1 resimden 1.
    • Using the plastic opening tool, gently pry off the plastic LCD screen frame around the entire perimeter.
    • Be careful while prying the frame off, because the plastic tabs that hold it in may break.
  3. Lenovo ThinkPad T400s LCD Screen Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad T400s LCD Screen Replacement: adım 3, 2 resimden 2.
    • Remove the LCD connector by pulling on the ribbon cable at the connection.
  4. Lenovo ThinkPad T400s LCD Screen Replacement: adım 4, 1 resimden 1.
    • Lift the LCD screen out to replace.
    • Make sure to remove the screen with both hands and from opposite edges of the screen.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Christopher Noone
235 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 6-18, Maness Spring 2015 Cal Poly, Team 6-18, Maness Spring 2015 üyesi
CPSU-MANESS-S15S6G18
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 2,605
