Ana içeriğe geç
Lenovo ThinkPad T410s Keyboard Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T410s Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over.
    • Push and hold the locking switch to the left.
    • Pull the battery out with your other hand.
  2. Lenovo ThinkPad T410s Keyboard Replacement, RAM: adım 2, 2 resimden 1. Lenovo ThinkPad T410s Keyboard Replacement, RAM: adım 2, 2 resimden 2.
    • Remove the single Phillips #0 screw grin the back panel.
    • Pull the back panel off.
  3. Lenovo ThinkPad T410s Keyboard Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad T410s Keyboard Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad T410s Keyboard Replacement: adım 3, 3 resimden 3.
    • Pull the metal prongs at the side of the RAM away from each other.
    • The RAM will pop out of its socket when done correctly.
    • Pull the RAM out.
  4. Lenovo ThinkPad T410s Keyboard Replacement, Hard Drive: adım 4, 2 resimden 1. Lenovo ThinkPad T410s Keyboard Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Remove the single Phillips #0 screw that secures the hard drive cover.
  5. Lenovo ThinkPad T410s Keyboard Replacement: adım 5, 2 resimden 1. Lenovo ThinkPad T410s Keyboard Replacement: adım 5, 2 resimden 2.
    • Flip the black plastic tab out.
  6. Lenovo ThinkPad T410s Keyboard Replacement: adım 6, 2 resimden 1. Lenovo ThinkPad T410s Keyboard Replacement: adım 6, 2 resimden 2.
    • Pull the hard drive out.
  7. Lenovo ThinkPad T410s Keyboard Replacement, Keyboard: adım 7, 1 resimden 1.
    • Remove the Flathead 2.5mm screw.
  8. Lenovo ThinkPad T410s Keyboard Replacement: adım 8, 2 resimden 1. Lenovo ThinkPad T410s Keyboard Replacement: adım 8, 2 resimden 2.
    • Wedge the flat end of a spudger, or plastic opening tool, under the end of the keyboard and pry up.
  9. Lenovo ThinkPad T410s Keyboard Replacement: adım 9, 2 resimden 1. Lenovo ThinkPad T410s Keyboard Replacement: adım 9, 2 resimden 2.
    • Slide the keyboard out of the way until you can see what's underneath it.
    • The keyboard is still attached with a ribbon cable so don't try to fully remove it.
  10. Lenovo ThinkPad T410s Keyboard Replacement: adım 10, 1 resimden 1.
    • Use the flat end of a spudger to unplug the keyboard connector from the laptop.
    • Pull the keyboard out.
Sonuç
Blake Wilson
117 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 79
Her zaman: 3,167
