Ana içeriğe geç
Lenovo ThinkPad T430s Display Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T430s Display Replacement, Battery: adım 1, 3 resimden 1. Lenovo ThinkPad T430s Display Replacement, Battery: adım 1, 3 resimden 2. Lenovo ThinkPad T430s Display Replacement, Battery: adım 1, 3 resimden 3.
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s Display Replacement, Display: adım 2, 3 resimden 1. Lenovo ThinkPad T430s Display Replacement, Display: adım 2, 3 resimden 2. Lenovo ThinkPad T430s Display Replacement, Display: adım 2, 3 resimden 3.
    • Rotate your ThinkPad so the back side faces you.
    • With the Phillips #1 screwdriver, remove the two 70 mm screws in the right and left corners. These may be covered by plastic covers.
    • Open the ThinkPad so the screen faces up. Lift the screen from its hinges.
  3. Lenovo ThinkPad T430s Display Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad T430s Display Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad T430s Display Replacement: adım 3, 3 resimden 3.
    • With the Phillips #0 screwdriver, remove the two 50 mm screws securing the plastic display case.
    • Wedge the flat end of the spudger in between the display case and the screen. Unsnap the top case from the bottom piece holding the screen.
    • Remove the case and set it aside.
  4. Lenovo ThinkPad T430s Display Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad T430s Display Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad T430s Display Replacement: adım 4, 3 resimden 3.
    • Unscrew the four 30 mm screws holding the screen to the case.
    • Lift the screen out of the case.
    • Flip the screen over.
  5. Lenovo ThinkPad T430s Display Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T430s Display Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T430s Display Replacement: adım 5, 3 resimden 3.
    • Peel away the tape holding the cable down with the flat end of the spudger.
    • Pull the cable out of its socket.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 75
Her zaman: 3,007
