Ana içeriğe geç
Lenovo ThinkPad T430s Fan Assembly Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T430s Fan Assembly Replacement, Battery: adım 1, 3 resimden 1. Lenovo ThinkPad T430s Fan Assembly Replacement, Battery: adım 1, 3 resimden 2. Lenovo ThinkPad T430s Fan Assembly Replacement, Battery: adım 1, 3 resimden 3.
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s Fan Assembly Replacement, RAM Stick: adım 2, 3 resimden 1. Lenovo ThinkPad T430s Fan Assembly Replacement, RAM Stick: adım 2, 3 resimden 2. Lenovo ThinkPad T430s Fan Assembly Replacement, RAM Stick: adım 2, 3 resimden 3.
    • With the Phillips #0 screwdriver, loosen the two 30 mm screws holding down the RAM stick plate.
    • Pry up the plate and set it aside.
  3. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 3, 3 resimden 3.
    • Use the pointy end of the spudger to bend the bars holding the RAM stick in place.
    • Lift the RAM stick up and out of the stick holder.
  4. Lenovo ThinkPad T430s Fan Assembly Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Unscrew the 40 mm screw with the Phillips head #1 screwdriver.
  5. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 5, 1 resimden 1.
    • Pull the hard drive out with the black ribbon attached to it.
  6. Lenovo ThinkPad T430s Fan Assembly Replacement, Motherboard: adım 6, 3 resimden 1. Lenovo ThinkPad T430s Fan Assembly Replacement, Motherboard: adım 6, 3 resimden 2. Lenovo ThinkPad T430s Fan Assembly Replacement, Motherboard: adım 6, 3 resimden 3.
    • Flip your ThinkPad over so the back faces up.
    • With the Phillips #0 screwdriver, remove the seven 50 mm screws on the outer edge of the case.
    • Remove the two 70 mm screws in the upper corners of the case.
    • Remove the five 50 mm screws in the battery compartment.
  7. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 7, 3 resimden 1. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 7, 3 resimden 2. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 7, 3 resimden 3.
    • In the RAM compartment, pry the black, white, and grey wires up from the Wi-Fi card with the pointy end of the spudger.
    • Remove the 30 mm screw holding down the Wi-Fi card with the Phillips #0 screwdriver.
    • Pull out the Wi-Fi card.
    • Remove the 60 mm and 30 mm screws in the RAM stick compartment.
  8. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 8, 1 resimden 1.
    • Remove the 50 mm and 30 mm screws in the hard drive compartment.
  9. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 9, 3 resimden 1. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 9, 3 resimden 2. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 9, 3 resimden 3.
    • Flip the ThinkPad right side up and open the lid.
    • Wedge the flat end of the spudger between the keyboard and the palm rest. Push the keyboard away from you until it pops out.
    • Lift the keyboard from the palm rest to expose the ribbon connecting the keyboard to the motherboard.
    • Pry the keyboard ribbon up from the motherboard with the flat end of the spudger.
    • Set the keyboard aside.
  10. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 10, 3 resimden 1. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 10, 3 resimden 2. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 10, 3 resimden 3.
    • Remove the two 50 mm screws from the case covering the disk drive.
    • Thread the wires that come from the RAM compartment up through the hole in the motherboard. Unwind them from the computer case.
    • Wedge the flat end of the spudger in between the palm rest and the bottom case. Unsnap the edges of the palm rest and case until they disconnect.
    • Lift the palm rest up from the motherboard.
  11. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 11, 3 resimden 1. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 11, 3 resimden 2. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 11, 3 resimden 3.
    • Pull the red, blue, and white wires in the left corner away from the motherboard.
    • Peel the snap securing the ribbon with the pointy end of the spudger.
    • Pull the ribbon back towards you.
  12. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 12, 3 resimden 1. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 12, 3 resimden 2. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 12, 3 resimden 3.
    • Rotate the ThinkPad so the back side faces you.
    • With the Phillips #1 screwdriver, unscrew the two 70 mm screws from the corners.
    • Lift the screen and pull it out of the hinges. Set the screen down behind the rest of the ThinkPad.
  13. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 13, 3 resimden 1. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 13, 3 resimden 2. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 13, 3 resimden 3.
    • With the pointy end of the spudger, lift the plastic snap holding down the SN4 LVDS cable. Pull the cable out of the clasp towards you.
    • Pry the SN4 LED cable out of where it connects to the motherboard.
    • Set the display aside.
  14. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 14, 3 resimden 1. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 14, 3 resimden 2. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 14, 3 resimden 3.
    • With the pointy end of the spudger, lift the plastic snap securing the ribbon at the front of the ThinkPad.
    • Pull the ribbon out of the clasp towards you.
  15. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 15, 3 resimden 1. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 15, 3 resimden 2. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 15, 3 resimden 3.
    • Unscrew the 90 mm screw, five 50 mm screws, and four 30 mm screws on the motherboard using a Phillips #0 screwdriver.
    • When you remove the screws, the small motherboard stick in the top right corner will pop out of the case. Pull it out.
    • Lift the motherboard out of the case.
  16. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 16, 3 resimden 1. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 16, 3 resimden 2. Lenovo ThinkPad T430s Fan Assembly Replacement: adım 16, 3 resimden 3.
    • Flip the motherboard over so the back faces up.
    • Loosen the four screws securing the heat sink to the motherboard. The silver metal rectangle on the front of the motherboard will fall off. Set it aside.
    • Lift the fan and heat sink away from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Matthew Hill
190 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 27
Son 30 gün: 73
Her zaman: 847
