Ana içeriğe geç
Lenovo ThinkPad T430s RAM Stick Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T430s RAM Stick Replacement, Battery: adım 1, 3 resimden 1. Lenovo ThinkPad T430s RAM Stick Replacement, Battery: adım 1, 3 resimden 2. Lenovo ThinkPad T430s RAM Stick Replacement, Battery: adım 1, 3 resimden 3.
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s RAM Stick Replacement, RAM Stick: adım 2, 3 resimden 1. Lenovo ThinkPad T430s RAM Stick Replacement, RAM Stick: adım 2, 3 resimden 2. Lenovo ThinkPad T430s RAM Stick Replacement, RAM Stick: adım 2, 3 resimden 3.
    • With the Phillips #0 screwdriver, loosen the two 30 mm screws holding down the RAM stick plate.
    • Pry up the plate and set it aside.
  3. Lenovo ThinkPad T430s RAM Stick Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad T430s RAM Stick Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad T430s RAM Stick Replacement: adım 3, 3 resimden 3.
    • Use the pointy end of the spudger to bend the bars holding the RAM stick in place.
    • Lift the RAM stick up and out of the stick holder.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 877
