Ana içeriğe geç
Lenovo ThinkPad T431S Charging Port Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T431S Charging Port Replacement, Charging Port: adım 1, 2 resimden 1. Lenovo ThinkPad T431S Charging Port Replacement, Charging Port: adım 1, 2 resimden 2.
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
    • After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
  2. Lenovo ThinkPad T431S Charging Port Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad T431S Charging Port Replacement: adım 2, 2 resimden 2.
    • Unscrew the single, 3.0 mm screw with a Phillips #1 screwdriver bit that holds the charging port housing into place.
  3. Lenovo ThinkPad T431S Charging Port Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad T431S Charging Port Replacement: adım 3, 2 resimden 2.
    • Remove the small, white connector cable by prying it from the connector with a plastic opening tool.
    • Remove the charging port assembly.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 13
Son 30 gün: 30
Her zaman: 4,196
